here is a list of what ive picked out for a build after a few revisions, I just want to make sure everything is compatible here, I have a Fatshark headset and a DX6E controller already
total comes out just below $200 am I missing anything? everything decent quality by the looks of it?
naze is a great place to start as they have been around for a bit, and there is a lot of info on them. If that is what it says in the description then you should be fine, some of those don't come with PWM inputs. Though if you can do PPM it is usually preferred. I started out on PWM and I moved to SBUS. PWM certainly is a lot simpler to work with and mod, but SBUS and PPM use fewer wires. No real rush to use anything but PWM for now.I'm new to this so I'm sorry if I get anything wrong, but the FC (flight controller I'm assuming) says "* 2 x 8 pin JST-SH Socket (PPM, PWM, SERIAL RX, GPIO, ADC, 3V, 5V, GND)'' under the description.
and like I said I'm pretty new, what is the advantage of one FC over the other? the naze was just what was recommended from a video I watched =/
