FlySky FS-i6 wont work after CleanFlight firmware update
Discussion in 'Parts & Components' started by BL Swagger, Dec 7, 2017.
  1. mozquito1
    In the picture where are the ground wires off the esc's? I think they should be on the edge of the board. I can see you have power & ground on them rails.
  2. BL Swagger
    BL Swagger Well-Known Member
    I have a 4in1 20a esc so the ground and power connect directly to the PDB.
    After I reset the flight controller (new firmware, everything), I put the props on like you suggested and it flipped over. But then I remembered I'm prone to putting the props on upside down... so I dbl checked and they were on incorrect. Fixed the props and then tried again... Lift off.
    What sucks now.. is that I lost 3 screws to a motor on the test flight and now its grounded till I get more screws.
    Fix 1 problem, 3 more rise.
    mozquito1 likes this.
  3. mozquito1
    Well seeing as your ordering stuff. Get some blue loctite. Or a cheaper version.
    It will stop them screws vibrating loose.
    Make sure to tighten all screws before everytime yo go out. Get some nylock nut for your props if not already.
