Esc troubles, and addvice?
I started on Simonk & went through all the teething with them so by the time blheli multishot then dshot came out its too easy. Simonk are big bricks about 25g each with cable you wire a house with.
If you can fly acro on Simonk you can fly anything. Like a flying tank with helium balloons & a hair drier.
I only own one 4in1 I have on on a 130mm. It's got about 30 hours on it & still going but I just rather piece of mind in separates. A 3in1 is no good to anyone unless you got a tricopter setup on a shelf. Or a twin motor with diff.
Alright I think that might have been the issue, I always tried to throttle up after I crash to see if I can right it's self or take off from after crash. I will be on point with my disarm switch now!!!!
Damn even 2 "sets" a year would be good for me! Once I get my new parts I'll let your guys know if the problem stops!
Spare switch = turtle mode.
If I feel I have lost control under 12' then I throttle down ASAP. As going for a punch out you may just plough straight into the earth harder than you where going to.
I'm still not that good an acro flier I stay high & safe = stuff lasts that way.
I fly both Los & fpv Los I lose orientation at about 150' not every time but if I do I jut cut it as that's how I deal with the panic. Rather than flap about mashing the stick. Just set it down as controlled as I can.
