Buying my first racing quadcopter need some input
Discussion in 'Getting Started' started by subbmitt, Jan 6, 2017.
  1. subbmitt
    subbmitt Member
    Hi so im looking a 2 quads and they come to about the same price with whole set up
    Eachine Wizard x220 or eachine falcon 250 pro I will be flying FPV
    Artofacks1 likes this.
  2. Artofacks1
    Artofacks1 Member
    Highly interested in this advice as well.
    subbmitt likes this.
  3. holtneil
    Go the 250 falcon
  4. subbmitt
    subbmitt Member
    so i have watched alot of reviews on both quads and everyone loved the Eachine Wizard x220 its fast good camera handles well and not so much with the falcon because its heavy and it has angled motor mounts that can be removed thought i would just tell you what i have reviewed
  5. Artofacks1
    Artofacks1 Member
    I just seen this review and looks like the 250 falcon not recommended
    subbmitt and holtneil like this.
  6. Artofacks1
    Artofacks1 Member
    and they are calling the Wizard the 2016 drone of the year...
    MrkThMn, subbmitt and holtneil like this.
  7. qball
    qball Member
    iv just got the wizard (my first quad), word of warning if you are getting it from banggood.com buy some props from amazon. They are out of stock on the props, on the comments some people have been waiting 2 3 months.
    I got the £160 wizard 4 sets of props, control, FPV ready to fly (ish) you have to set up arming it in betaflight be for it will fly.
    the FPV antenna was useless (or the sent us a duff one)
    but on the plus side iv had some big crashes 20ft drop, 2 trees, a wall with no damage at all to the quad. its built like a tank. I'm learning to fly it with stable mode turned off (its not going too good getting there thow)
    I'm having loads of fun with it
  8. subbmitt
    subbmitt Member
    nice thanks for the advice
  9. Artofacks1
    Artofacks1 Member
    you think i can stream the camera view to my iphone while I save up to buy a googles?
  10. subbmitt
    subbmitt Member
  11. qball
    qball Member
    It might just of been a duff antenna it only worked 10ft away, Iv got a clover leaf coming tomoz ill let you know if it works
    I'm new to this stuff but to stream it to your phone I think they work on 2.5GHz and the FPV transmitter on race drones is 5.8 (I'm probably wrong on that, I remember reading something abut it on about the phantoms 4)
    check out your local stores for used FPV googles I got some fatshark v4 googles with a micro drone for £120
  12. subbmitt
    subbmitt Member
    thats a good idea ill have to go check it out we only have 1 rc store here
  13. subbmitt
    subbmitt Member
    how well can you see in the camera with the goggles ? is it pretty clear or blurry
  14. qball
    qball Member
    fpv under 300
    the screen is low res 320 x 240 (basic model) and it looks far away but iv heard even the £500 fat sharks still look like its looking down a corridor
    but the main thing is there is no lag on them and for what I payed I'm made up with them
  15. Artofacks1
    Artofacks1 Member
    I'm gonna research that, it's the only thing holding me up from ordering. I also dig how on my propel I can use my phone ,
  16. qball
    qball Member
    my mistake about the antenna got my clover leaf antenna on now still had the same problem, had the channel on the transmitter set up wrong pin 1 and 2 turned on 3 4 5 6 turned off picture looks sweet now. Iv not had a chance to test the range out side due to weather
    subbmitt and Artofacks1 like this.
  17. MrkThMn
    MrkThMn Member
    Hey qball! Sounds like we may have watched the same YouTube review to make our purchases, haha! I'm curious what remote you are flying with? I went for the Taranis over the FlySky and I'm having issues getting the receiver to talk to the quad... Everyone is just saying plug it in, bind it, give it a quick check in Clean/Betaflight and go fly but I plugged mine in, bound it and... nothing happens. :mad: I've watched so many positive reviews for the Wizard that Im sure Im just missing something but I've spent like 15 hours trying to figure this out so far with no luck.
  18. qball
    qball Member
    I'm on the fly sky i6
    had the same problem couldn't get props spinning. I'm on beta flight but I think I works the same.
    In the controller I went in to settings- then aux channels- and put channel 6 on VrB (one of the switches I wanted to arm it) on the flysky you only have channel 5 and 6 to play around with
    then in betaflight go to modes and where it says arm, move the orange slide bar to right hand side so when you move the switch to on it falls in that area. select aux1 on mine that's channel 6 (when you flick the switch you will see a line move into the orange bar)
    so now when I move VrB switch that arms it so I can fly. if I'm picking it up turn VrB off so I don't chop my fingers off
    just remember to click the save button or it wont save
    MrkThMn and subbmitt like this.
  19. MrkThMn
    MrkThMn Member
    Thanks for the feedback!!
    I had suspected that it might be an arming issue so I'm going to look into this tonight! I'm hoping once I set the arming up in the Taranis, I'll be able to see it (the Taranis) in Clean/BetaFlight. That's been part of my frustration; not only can I not control the quad from the remote but when I get the quad successfully pulled up in CleanFlight I go to the Receiver section and when I move the sticks around nothing happens with the colored sliders on the screen. It's like it's not even turned on which is what has made me think the problem was between the receiver and the FC. I'm excited to play around with getting it armed though cause I had run out of ideas.
    I have been working in CleanFlight simply cause I found a really in-depth tutorial for it so it was nice to have my hand held. From what I've seen it should be pretty close to BetaFlight though, just a little more simplified. This might be a good time to step up to the big leagues, haha!
  20. qball
    qball Member
    did you plug the battery in when you have it hooked up to the computer
