ARming not working after correcting FCB orientation
alex_.
In my previous thread I asked for help because my quad was flipping off of take off. This turned out to be that the FCB was pointing the wrong way in the quad so I had to change the direction in betflight to point forward.
Now the quad matches the betaflight diagram when I tilt and turn it but now for some reason it wont arm. I set up one of the switches on my x9d as an arm switch but now I switch it and the quad wont arm for some reason. all the other switches work tho.
(do note: When I go to the motors tab in betaflight the motors can all spin and I made sure the direction was correct)
Why isn't the quad arming? (my quad is a BNF Eachine Wizard x220)
Update: Solved! throttle and yaw switched themselves so my throttle was above the throttle_min to arm the quad.
One thing, your quad won't arm when you're throttle is above zero. When you turn your Taranis on, is it giving you a throttle warning? Next, when you go into the Betaflight receiver tab, are all your channels set to 1000-1500-2000? In configuration tab, ESC protocol should be set to DShot600
