X666 quad still wont calibrate properly and take off straight
irishluck
I've tried to calibrate my motors maaaaany different times and it is still not working properly.
The video I am posting on here is showing the flight after attempting to calibrate the ESC again.
You can see that the quad only likes to take off on one side. Also when I turn the throttle down you will see that 2 motors stop almost instantly and the other 2 wind down slowly.
The 2nd video shows me trying to calibrate the ESC's.
What im concerned about is that noises it makes.
The youtube video that shows how to calibrate says that it will make 2 beeps and then you push the throttle down. As you can see in my video is that the FC doesnt do this.
I need help. I cant get this to take off properly.
Well the only thing I can think of is the actual programming for each ESC. I'd try switching out some ESCs and see if the problem 'moves' with the ESC.
Those ESCs have various parameters, maybe they all don't match. You may have at some point entered programming mode with all your experiments and unknowingly changed something.
