C
CMEC
Guest
Systems batteries for UAVs for longest flights and capable of lifting heavy payloads.
Handmade to order and ready to use. Designed & assembled in the Netherlands.
Panasonic NCR18650GA li-ion cells. High energy density. Never compromise. Ultra durable.
Battery quality is extremely important. These kind of cylindrical Li-ion cells used to power electric vehicles Tesla have at least 70% more energy density per weight and are less heavy than Li-Polymer types.
For UAVs which are suitable for various industry applications, such as television broadcasting, signal relay, video surveillance, surveying and mapping, aerial photography, pipeline and powerline patrol, medical aids, agriculture, a battery pack assembled with cell type 18650 with high energy density it is translated into a 70% longer flight time, or more heavy payloads!
Another big benefit:
With more cylindrical batteries 18650 Li-ion type, interconected in parallel, the battery pack has more power and it’s more safe, because entire power supply system can’t fail, unlike battery pack with Pouch Li-Polymer cells are only connected in serial , if only one fails, drone is in freefall.
Photo: Left: NCR18650PF | Middle side: NCR18650B | Right: NCR18650GA
For UAVs which are suitable for various industry applications, such as television broadcasting, signal relay, video surveillance, surveying and mapping, aerial photography, pipeline and powerline patrol, medical aids, agriculture, a CMEC battery pack with high energy density it is translated into a 70% longer flight time, or more heavy payloads!
Photo: NCR18650GA 6S6P 25.2V 60A battery pack (13,5 x 13 x 5,5cm)
Example:
6S6P60A – Retail: €330,00 + VAT
Specifications.
Cell count: 36
Cell type: Li-ion Panasonic NCR18650GA 10A
Battery pack capacity: 21Ah
Voltage (nominal) 22.2V
Max.voltage: 25.2V
Power: 529Wh (calculated on 100% SoC)
Continuous discharge: 60A (for a long lifespan of a battery, must be not overrun this value)
Peak discharge (10sec): > 80A / 1770W – In this case may affect lifespan of battery pack , read below on this page what shortens lithium battery life.
Max. charging current: 10A (for maximum energy storage)
Weight: +/- 1800g (including wiring harnesses, connectors & covering)
Physical dimensions: 23 x 5.5 x 7cm / 13,5 x 13 x 5,5 cm, or fully customizable on order.
Discharge connector: XT90
Discharge wire type: Flexible silicone insulated copper 12AWG
Discharge wire length (pack to connector end) +/- 100mm
Balance plug: JST-XH 7-pin
Balance wire length (pack to connector end): 40mm
External, the battery pack are covered in Blue/Black PVC film (0.12mm). Inside, the cell block is surrounded with a laminated aramid fiber shield (0.50 mm).
These battery packs are not protected by the internal BMS, and are manufactured for the intended to use with a external charger with proper protection and balancing circuitry for this kind of lithium-ion cells (Read below on this page, cautions and instructions) CMIUTA Electric Company will not be liable for any damages that are caused by violations of the precautions in this specifications.
Efficiency:
With this kind of battery (6S6P60A) fully charged, a special drone used for emergency services or industrial purposes with weighing about 5kg including payload can continuous fly for 70 minutes, or to cover in-flight the equivalent of a surface of 100 hectares (1.000.000 m2)
Photo: NCR18650GA 6S6P 25.2V 60A battery packs (23 x 5.5 x 7cm)
6S4P40A – Retail: €230,00 +VAT
Specifications.
Cell count: 24
Battery pack capacity: 14Ah
Max.voltage: 25.2V
Power: 352Wh (calculated on 100% SoC)
Continuous discharge: 40A (for a long lifespan of a battery, must be not overrun this value)
Peak discharge (10sec): > 60A / 1330W – In this case may affect lifespan of battery pack, read below on this page what shortens lithium battery life.
Max. charging current: 8A (for maximum energy storage)
Weight: +/- 1200g (including wiring harnesses, connectors & covering)
Physical dimensions: 16 x 5.5 x 7cm, or fully customizable on order.
Photo: NCR18650GA 6S4P 25.2V 40A battery packs (16 x 5.5 x 7cm)
How It’s Made: A clean, safe and precise engineering design process!
Cells are extra-insulated with a gasket against short-circuit (the outer rim of the top of the cell is part of the negative terminal). Then are exactly welded and assembled, spending more atention to detail and safety. Inside pack, under cabling, the cell block is surrounded with a laminated aramid fiber shield (0.50 mm)
About order, payment and delivery.
Order processing time: 24 hours. Manufacturing process: 5 – 30 days, depending on item quantity ordered. Payment metode: through invoice (Direct bank transfer or Paypal service). See below the price list for 3S / 4S / 6S battery pack configuration & go to the order page . Please make all payments in € (EUR). Delivery to non-EU countries may cause additional custom, taxes and fees.
Flight in confidence! The CMEC batteries has one of the strongest warranties of any battery pack manufacturer. Two Years Warranty (read instructions, cautions and warnings)
See below a chart with all battery packs assembled with Panasonic NCR18650GA 3.5Ah 10A, ordered by configuration, capacity and weight. Price list.
Instructions, cautions and warnings:
Example:
Specifications.
Cell count: 36
Max.voltage: 25.2V
Efficiency:
Specifications.
Cell count: 24
Max.voltage: 25.2V
- These battery packs are not protected by the internal BMS, and are manufactured for the intended to use with a external charger/controller with proper protection and balancing circuitry for this kind of lithium-ion cells (read below prohibited actions)
- Because is a new battery pack assembled, the cells have from factory a voltage for storage state, and needs to be fully charged to 4.20V/cell before first use. After that, you can downgrade the charger setup to max. 4.10V/cell, for a long lifespan of battery. Also, don’t discharge below 3.10V/cell, for same reasons (read below how to prolong battery life)
- CMIUTA Electric Company don’t have any responsibility and aren’t liable for any damage caused through improper use of these battery packs and chargers, or to use for purposes other than mentioned on product specifications.
- CMIUTA Electric Company will not be liable for any problems caused by design defects of the electric vehicle, chargers or electronic devices, located in propriety of customers.
- DO NOT short circuit
- DO NOT force a reverse-charge or a reverse-connection
- DO NOT overcharge or over-discharge
- DO NOT modify, disassemble, puncture, cut, crush, or incinerate
- DO NOT expose to liquids
- DO NOT use or place the battery a high temperatures (more than 80°C)
- DO NOT connect the battery directly with AC plug (outlet) or car plugs.
- High temperatures.
- Overcharging or high voltage.
- Deep discharges or low voltage.
- High discharges or charge current.
