As you said with the toys, quad on first then transmitter with throttle DOWN. To bind push throttle UP then DOWN again. Should be good to go now.make sure when syncronizing that both handset and quad are off . turn on quad then handset then bind together
this should work and allso when useing video make sure you turn camara off before quad or you get corrupted files
phil.
I'm gonna go with DJI dude and Jimbir on this one. I double checked the manual and it very clearly instructs you to turn the Tx on first then turn on the quad. Push the throttle full up and then full down. There should be one clear sound from the Tx. Actually. Tx first then plug in the battery is true for every other quad I own.i started and played with the drone, after battery was empty, i recharged it and when i put the battery back in it flashes the LED's and it doesen't si.cronize with the remote. what can i do?
