UpMostBeast
I am having a problem with my seriously pro f3 flight controller where one of the motor channels has a delayed response to stick input. I can see it on cleanflight where when I raise the throttle, motor channel 3 stay at 1070 (or whatever my min throttle is) while the others raise normally until the motor ouputs are at 1300 or so and then motor channel 3 begins to respond and raise at the same rate as the other channels are. Note that it doesn't matter which esc I am using ( I have some racerstar 20a lite using oneshot125) and the motor channel 3 works perfectly fine when I override it from within the cleanflight configurator. I don't know if this is a hardware or a software issue. I can note that the flight controller is actually a clone from banggood. Any help or knowledge would be appreciated
