yangdaonline
INTRODUCTION
Sky Eye-18HZ is a gimbal designed for X18 zoom camera for drone aerial inspection,surveillance,research and rescue mission,which can be easily installed on any multirotor platform.It consists of 1080p X18 optical zooming camera and a 3-axis high stabilized gimbal,which is able to take and record 1080p 30fps video to an on board TF card, giving you a stable eye in the sky that can be controlled via drone pilot or a secondary individual allowing for an overhead view that can cover a large amount of ground quickly and effectively. The X18 zoom function will allow you to remain at a distance yet zoom closely in on anything that requires your attention.
Sky Eye-18HZ provides an outstanding wiring hub design for RC receiver and video output port(AV and HDMI),which makes wiring pretty easily.Also the gimbal offers 2 smart speed modes:FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick.LOW speed mode is used for large zoom range,will enable you to target the object more accurately.
Sky Eye-18HZ has two video output ports,HDMI(1920*1080*60fps ) and Analog,which makes it possible to use traditional analog 5.8G video downlink or HD video downlink.The photo/video/playback functions can be chosen by a 3-gear switch on your radio.
FEATURES
1)586grams,light weight
1)1/3 inch 4MP CMOS sensor
2)18X optical zoom,CVBS and 1080P/60 HDMI output for video downlink
3)1080P/30 H.264 video recorded for on-board TF card
4)PWM control and serial command control
5)Intelligent wiring hub design for RC receiver and video output(AV and HDMI)
6)3-aixs high stabilized gimbal system
7)Adjustable control speed: SLOW speed for large zoom range,accurate.FAST speed for small zoom range,sensitive and quick.
8)One key back to center
VIDEO
PRODUCT PHOTOS
FEATURES
VIDEO
PRODUCT PHOTOS
