settings
joseph
f450 running 1.9 steven kk2.1.5 board it is flying good. my q is x650 f v4 running 1.8pro stevens kk2.1.5 if i use the same setting do u think the x650f-v4 will act the the same reason jam asking is the x650f v4 wants to flip forward upon lift off. thanks.
Hmm, maybe Neil can beter answer this, but all of the stabilization should be the same, but the .9 has no autolevel.
I think it has the option to turn off auto level.
V1.19S1 Pro Issue 1
Various settings – First option listed is the default
Self-Level
* Aux – AUX channel controls the self-levelling function.
* Stick – Turn on Self-levelling by holding the aileron to the right when arming or disarming. Turn it off with left aileron. Note, if you only connect a 4 channel receiver to the KK2.1.X with Roll, Pitch, Throttle and Yaw then set Self-Level to Stick.
* Always – Self level is always on.
* None – Ignores the Accelerometers. Use if your Accelerometer is faulty and won’t calibrate. Note, you will NOT be able to use self level.
Hi mate Check your CG, On the early 1.9 the self level was set low as it was for the acro board or if an ACC was down on the board , Steveis did a lot of work on the set up and was asked to up the self level like Jackson said its been done, 1.9 is more aggressive This is why steveis says use 1.8 for normal KK2.1.5 and normal type flying default is good for 99% of the quads out there
