Quad Spinning CCW on ground, Unable to take off
OK I will take out and fly. Ground effect can be the reason. Thanks for the input .
I'm flying in the normal mode.
I have rolled my battery on foam and fixed it on the base plate. Did CG is balancing everytime before take off.
ok mate to be honest i have never seen a quad play up as much as yours are all the parts new that you have used
Good News. You were right, it was turbulence problem in that room.
I was able to lift the vehicle to more than 15 mts. Not instantly but by slowing giving throttle to more than 50%. I dint crash it.
Initially, that is around 10 to 15% throttle, it was moving here and there but after 40% throttle, it took off with ease but correction ought to be given always in all the channels. What I feel is that, Since Im not expert in flying, im unable to control it precisely... I will update you more tomorrow morning after flying the vehicle.
Thank you Holtneil for supporting me with valuable inputs all the time.
Hi mate you need to set up the i and p gains in all axis, i know you may not want to mess with it now but it may make it more stable , what you need is watch this videos the videos are done by the guy how made to kk board
Thank Holtneil for the video.
One more observation :
Arming is happening when left rudder is given, But actually as per the kk2.1 manual, arming should happen for right rudder.
I thought the rudder channel is reversed and tried to correct it using t6config and digital radio s.w. There i could see that rudder channel is not reversed, it is moving in proper direction.
Is there any setting in FC board to correct this problem ?
or else i should reverse the Tx channel using t6 config
IT does sound like it is backwards if you put battery on quad ,then go into menu and find monitor this will show you what the transmitter sticks are doing ie yaw right = yaw right , forward=forwards look at rudder make sure its right as i think its backwards , and this will make quad strange to fly as you rudder right the front should spin to the right and back to the left
Can you take it outside and get it up off the floor ground affect will act on the quad till its off the floor , may be now its just a trim problem once its up in the air you should be able to trim it , dont have it in self level mode yet fly in normal mode , some times self level will make quad drift if not set up right p and i gain can also make this happen , once it flys your have to set up the p and i gains
i see your battery is inside make sure when you put it in that the balance is right and if you have a built in pcb on bottom plate that it cant short out on the battery , cover all solder joints so nothing can rub on battery case
i have this problem with my new mini quad. after a land crash unable to fly it back again..please check the video and let me know the solution :
Hey Sammy, it's always best to start your own thread... this one is years old.
Have you tried to recalibrate?
Bind it then do this:
Pull both sticks into the corners as shown, usually there will be some sort light pattern that shows it's taken. This is something that needs to be done fairly often on some quads, usually after crashes.
