I have posted these questions on multiple forums before and so far have yet to come across a straight answer as to how to go about fixing the problem I've been having with my first build.
This quadcopter has been earthbound for about 4 years now, and admittedly the first mistakes were due to a bad combination of parts that were too ambitious.
6S 5000maH turnigy Li-po
10x4.5 props
800kV turnigy motors
CC3D flight Controller
5 channel Tx/Rx
some generic but fairly sturdy frame
30A non-BEC ESC's
1500MaH Ni-Cd (for powering flight controller due to non-BEC esc's)
The quad is a bit on the heavier side, between 0.8 and 1.5kg's
Our initial problem? Far too much thrust, I was expecting a far heavier body and counted on being able to dial back the thrust enough. But the flight controller (LibrePilot) was not at all intuitive with changing throttle and power supplies to the motors. Many have suggested either buying a better flight controller or flashing new firmware onto it and using a different program, but the CC3D board was giving me all sort of problems with flashing new firmware and no guides I could find were that helpful at fixing that problem.
Eventually, I decided to lower my batter down to a 4S 5000MaH li-po instead, and should the thrust then be too low, I could add large 12" props to the frame to compensate.
The new setup is as follows
4S 5000maH Li-po
12x4 props / 6x3 props / 10x4.5 (there is an assortment for testing)
5 channel Tx/Rx
30A non-BEC ESC's
The quad is still a bit on the heavier side, between 0.8 and 1.5kg's
Here's were my most recent issues come into play
It seemed that even though I changed the battery from a 22.2v li-po (6S) down to a 14.6v li-po (4S), the thrust was still way to high to idle the propellers at minimum throttle. I've tried everything I can do on LibrePilot to remedy this issue, and I know the motors can have a lower RPM since doing the test where you find the lowest voltage at which the motor begins to turn. I just can't seem to find a way to make the lowest "tick" of throttle on the controller be the lowest amount of power sent to the motors.
(and as long as I'm listing problems with the current system, the throttle on it has been working really weird as well, where it goes up to about 10% throttle, holds at 50% until the stick reaches 50%, then ramps up more from there. I have tried adjusting the throttle curve but that seems to be of no use.)
I feel like this problem must be bigger as well, considering I saw almost no change in performance between the 6S li-po and the 4S li-po, but I'm at a loss as to why nearly cutting the voltage in half did nothing to affect performance.
I understand some of the hardware I'm using is old, I know there are better parts ion the market today, but I'm not going to sink any more money into this quadcopter unless there is a hopeful solution at the end of the shopping list. On batteries alone, I have spent 100$ just trying to troubleshoot and I have yet to make any progress since day one. If you suggest buying new hardware, please include a link and an explanation as to how that will help get things airborne.
10x4.5 props
5 channel Tx/Rx
30A non-BEC ESC's
4S 5000maH Li-po
5 channel Tx/Rx
30A non-BEC ESC's
