Newbie question
Tecknomarc
Hi all! new to the hobby, and thought i would add a FPV mod to my contixo f17. I added a VTX03 along with a runcam swift 2 camera and have Ev800 goggles. I get a solid crystal clear image for 3-6 seconds mostly, sometimes up to 30, then the screen goes to static for 20-30 seconds, and after that the image returns for another 3-6 seconds. Very frustrating!
OSD clock keeps running, so after one phase out it will be at 20 seconds, and the next time it phases in it will be at 50 seconds, so the clock keeps running even when there is no image.
running 7.8~ volts. The VTX03 still says it is broadcasting as it is cycling through the channel/band.
I have tried changing channels, bands, and transmitting power from 25mW-50mW-200mW, and no matter what i do it keeps losing signal!
the signal will always return after i cut and reconnect the power, albeit for shorter and shorter durations with each time.
I thought perhaps the transmitter was overheating, and i was going to glue a heat sink to it, however the signal loss happens even when i just start it up.
Is my system underpowered? Radio interference? I don't know what to do! Thanks in advance for any help.
Thanks for the reply! There is a spot to connect to power on the main board itself that measures 5.5v and it will not power the transmitter or the camera. The only way I can get it to run is to solder the power and ground directly to where the battery gets plugged into the unit.
I though the voltage thing was weird too!
