How set end points on Futaba T8FG
Hi,
how can I set the end points on my futaba T8FG respecting minimum throttle at 1000uS and maximum throttle at 1940uS (values read on cleanfligt in the receiver tab)?
It's a matter of adjusting your limits in conjunction with the receiver screen. Endpoints should be adjusted for AETR at 1000 min and 2000 max, then use your subtrim to adjust midpoint to 1500.
If I understood correctly adjust (minimum and maximum) on the transmitter observing the result on the receiver tab and so also for the midpoint. Is it correct? Meanwhile, thank you for your help :)
Exactly! As you adjust your transmitter, you'll see the values change in on the bars. Like most adjustments, it may take some back and forth 'till you get it right as sometimes when you adjust the midpoints, it will change the endpoints slightly and visa versa. Also, you may not be able to get them exactly to 1000/2000 and may find for instance you can only get 1998 or 1999. Nothing to worry about, this won't affect your flight.
