hk alien 560
berto1230781
Active Member
Hi guys I recently both this frame to change from a x650f frame. I'll be using the apm 2.6 with the alien 560. When using the alien 560 how would u setup the motor lay out? Should I use the xframe motor layout even though it doesn't look like an x? I tryed hover tonight when I switched my parts over from the x650f to the alien 560 and it wanted to spin upon take off. Check motor direction and props everything is good. Am I using the wrong motor layout? Thanks for the help
Hi mate yes use as an X frame it will only be different if you have a arm leading and behind this will be a + frame
the motor lay out is front left CW front right CCW, back left CCW ,back right CW , check the blades are right and the right way up ,this may help
Hi can you tell me where i go to post something, iam new here and just can seem to find where to post antthing, thanks so much
