Help Please!
bert bernardo
I have a eachine 250 racer. I am having an odd problem. When I power on the drone the Video transmits just fine, clear strong signal but after about one second when the drone starts to beep during its boot up routine I loose the video. Any Ideas? Thanks!!!
Interference. Do they not power up together. How do you have the camera on before it's start up,or plug lipo in. Do you have the means & knowledge to take the fpv system out. To test separate.
It all powers up together. Do you think it's a malfunction in another component that is causing the interference? This is not the first time I have used this drone. I guess trying to disconnect the other components and see if it affects the video. I think that may be easier than trying to supply power to the FPV system...thoughts?
shielding
Please Elaborate on Shielding :)
I would just unsolder vtx power & supply the voltage it says on it. 12v probably safe. Just jury rig a connector. Also check the vtx brass sma connection is not touching the frame. Not good.
