Help please. Wifi reciever
Noor369
Active Member
Hi. Can someone please tell me how does a wifi reciever looks like in bayangtoys x21 Drone? And where i can order new one
What makes you think it's the wifi module in your drone? Can you see it in the wifi settings of your iPhone or is it just not showing?
I already posted a thread about the problem i have. I think its the wifi reciever inside the drone it self that not working.
o_O ... There is no wifi receiver in the drone ! That is a wifi video TRANSMITTER.
Repeating myself for clarity:
The radio transmitter (held in your hands) is 2.4 GHz (not wifi) and has sticks on it.
The radio receiver is inside the quad (also not wifi) and receives your control commands.
The wifi transmitter is inside the drone to send you the video to your phone.
The wifi receiver is your phone mounted onto the radio transmitter for seeing the video.
Now to answer your question about what it looks like. It's one of those integrated circuit chips, along with some other parts,
that's part of the main board inside. Toy quads usually have everything on one main circuit board instead of individual circuit boards.
My transmitter is not connecting to the drone.. I dont know the reason..waht it could be..sometimes it connects and not response to my controls commands
Wi-Fi = Wi-Bother, the range is poor the lag is even worse. OK I suppose for kids toys around the house. That's about it.
It transmits 5.8ghz over WiFi signal. First I ever heard. So your phone or device has to have compatibility with that waveband. Maybe search for an app in playstore or whatever. He explain it in the video posted above.
Hi. I dont understand. Waht you mean not armed
"Armed" and "Connected" are two different things.
Connected just means that the quad and radio are ready and capable of communicating.
Armed means you want to activate the motors to begin flying.
You can't get "armed" without first getting "connected".
And just because you're connected, doesn't mean you're armed.
Watch the video again, it shows you exactly what to do !
Dude i think you didnt understand me at all. The (transmiter is not connecting to the drone) red on the remote control flashing
Perhaps if you were more concise in your terminology and the specifics of your problem we could all understand you better.
I submit as evidence:
Hi. I dont understand. Waht you mean not armed ....
Did you even watch that video ?
It's all explained there. He even shows you what to do and how to do it.
1.) First both sticks down and to the outside
2.) Then both sticks down and to the inside.
Now it's armed (or should be).
Notice there's also other stick movements required for calibration sequences too.
3.) Throttle stick fully down, then etc, etc.
The parts you're needing start at about 5:30 into the video.
Couple of tips
Turn Tx on, both sticks on 0 input
arm switch is off.
Plug in lipo, blue power led is on.
This is now connected.
So now you are about to stand back & start flying. So you remove the safety aspect now by arming the motors by flicking the arm switch, you throttle up & fly away:rolleyes:.
Then when the battery runs out :mad: & you have to land. Apply the switch again to turn on the safety aspect, which disarms the motors. You will have two things in your hands, Tx & quad if you don't disarm & you knock the throttle. Let's just say it won't be comfortable flying in bandageso_O
Hope this helps understanding what connect & arm-disarm means.
