Global x183 is not taking off
Mine starts this sequence almost immediately after power-up; however I'll go to YouTube using the search parameters that you furnished and see how it goes.
Thank you for taking the time to read my message and reply to it. :-)
When the calibration fails the quadcopter is useless and the error code keeps repeating.
The only way to fix it, is to do a successful calibration.
Lloyd
Hi everyone, i recently bought a follower x183 drone with original battery 7.4V 2200mAh, i charge battery for full 4-5hours with mobile charger and green light is come on fully charged. i try to test drone, 15 satelites, do the calibration, now drone lights is constant, so i put sticks to lower corner to start spinning blades, and get drone to 1m high, and when i go higher with drone higher fo about 10seconds, the drone inmediately starts flashing under lights and return home and take off, and lights is blinking, and i can't take off again, lights is flashing al the time, like (flash--1s---flash), then again when i reset drone and do again calibartion succesfuly, again the same thing. Do you know what the problem is? battery bad or?
Hi you need a volt meter check volt of battery before and after charging , 5 hours is a long time to charge also check does the battery feel puffed ( outer case ballooned out ) if it is puffed the battery is bad or going bad
Thanks guys, its battery when i charge to full its 8.4V but it can flight only 3 min., Do you know which battery i can buy for longer life?
