Flysky i6 help
Noob9875
I just got my i6 tx with ia6rx I am having issues with the setup I got on my gcs for openpilot and started to setup the control and my controls are not where they should
Throttle is vra
Fc switch is vrb
None of the accessories switches work I really need some help setting up everything thanks in advance
Did you hook up the CC3D cables to the correct slots on your RX as I explained? The cable numbers are from the pic I posted on the other thread. I also prefer to do any channel reversing with the transmitter instead of in Openpilot. It keeps the stick values (low to high) consistent in the interface.
You also need to go into the i6 menu and and assign the 3 position switch to one of the AUX channels (5 or 6) to able to use it for all 3 flight modes.
I may not be able to get back to you for any questions as a mod has chosen to severely curtail my posting ability.
Yea I hooked all the cables up the right way and after a couple hrs of playing with my tx I figured out the settings and got everything working and I'm reading the telemetry also so I'm very happy lol
