First build
Doug LaCombe
Hey guys, I just completed my first self built quad. The problem I'm having, when I start to throttle up, all 4 props start spinning. But, once the throttle gets between 35-50%, one of the motors stops. Need some help, what can I do to remedy this problem..
Thanks Jackson, esc's were initially calibrated. This is happening after 3rd flight. Once it started giving me trouble, esc's were recalibrated. Trouble continued.
Check all your connections for a cold solder. Could be a bad ESC, it's pretty common (That's why I always order 5). Bit of a pain in the a## but you may have to trade ESCs and see if it happens with the other motor
