Mikelib765
I have a micro f3 fc, flysky is6, and flysky ia6 receiver. Setup as pwm. Everything wired properly and bound. I setup up failsafe in clean flight to 885/2115 and channels 1-4 to auto and 5-6 to hold. Save and reboot. Reconnect to cleanflight. Turn off tx for failsafe test with receiver tab up, throttle pulse drops from 1000 to 885(same setting as failsafe). Everytime I change min failsafe pulse that is what the lowest throttle pulse is when tx signal is lost. Went into cli and tried to set rs_min_usec and rs_max_usec and reset failsafe settings, the throttle pulses go back to failsafe pulses so failsafe never works. Someone tell me a answer please. Tx failsafe also doesn't work, thank you.
