eachine wizard x220 help :/
alex_.
So i just got the eachine wizard x220, my first racing quad, and i dont know how to get it flying :/ do i have to plug it into my computer or something? Help plz :)
Did it say it was RTF ready to fly or NRF nearly ready. Before we start with the bind procedure. Does it have a rx in it.
Read your manual, probably have to "CLI" (Control Lever Initiation) maybe throttle down and to the left or right to bind it?
Turn Tx on. plug battery in quad, push both sticks to bottom left or bottom right. Apply throttle. The arm maybe on the sticks. You can change them in modes tab in cleanflight or betaflight. Better if you put the Arm on auxiliary1 & set the range.
Then on the Tx. Apply channel 5 to swd.
Then auxiliary 2 is modes on swc,
The 3 position switch. Set the range. You only have to set angle & horizon. And set Aux2 on the Tx to channel 6. If can't get the jist I'll write it in steps properly I'm in work at the moment.
cleanflight and beta flight are chrome extensions, i downloaded those and plugged the little usb thing into the computer and my drone but it didn't auto-connect...?
