can i use this reciever on my arduino uno?!?!
so i am building my very first arduino uno quadcopter. The ARDUIN UNO is the flight controller and it will recieve input from the reciever (RX). I was told by a local RC employee that the reciever (ESKY model:000095 EK2-0420 which i got from an old rc helicopter) i am using is D-BUS , and that the arduino does not understand this reciever protocol. i was recommended to use an S-BUS reciever with my arduino!!
basically i would like to know if this reciever i am using is actually D-BUS AND not PWM,PPM or anything else.
i would also like to know if the arduino can understand this reciever's protocol (language)
ANY HELP IS APPRECIATED
Well it's quite old, everything these days is 2.4GH.
Model : EK2-0420A
Name : 72MHz 6CH Receiver
Specifications:
(1) Type : FM
(2) Channels : 6
(3) Input Power : +5V
(4) Modulation Type : PPM
(5) Difference Frequency : 455KHz
(6) Frequency : 72MHz
(7) Weight : 15g
(8) Dimensions : 50*24*15mm
(9) Current Drain : 11.5mA
(10) Color : Dark Green
The PPM don't make sense though, looks like a PWM RX.
http://www.goodluckbuy.com/esky-fm-72mhz-6-channel-6ch-mini-receiver-ek2-0420a.html
Model : EK2-0420A
Specifications:
(1) Type : FM
(2) Channels : 6
(7) Weight : 15g
how can i know for sure weather it is PPM or PWM? i ask you this since each protocol imposes a different wiring method from the RX to the flight controller.
