Bad servo
Mirage G4
I have a wltoys V383 Assassin it has a bad servo does anybody know where I can get a the same servo to replace the bad one hasn't been flown once
Looks like you will have to source a replacement on your own GB has many parts but no servo. Have you looked for any identifying marks on it?
Also the specs I see don't make sense> Full Metal Servo: 0.8 sec/60°,3KG/cm 6V. I think it should be 0.08 sec.
These 2 are pretty close to your specs:
Inexpensive - Hitec HSR-1425CR
Expensive - MKS DS6630
Hitec HSR-1425CR
The specs call for 60° rotation.
Hitec Robotics Continuous Rotation Servo is a standard servo modified for continuous rotation. As such, the servo does not have any feedback system.
Those types are usually used for camera tilting/panning etc. The MKS DS6630 also CR is listed under Camera Gimbals servo.
My bad, I just assumed it was for gimbal. Now that I look at the V383 I see it's for motor adjustment.
