Arris x220 , newb needs esc sync advice
freebles
hey folks I'm new to the hobby and to this site!so, Hola! Konichiwa! Hello!
im having issues getting this Arris x220 pro. off the ground for the first time.
it seems motor 1 wants to spin at 2000 and every other motor goes to maybe 1400-1500
i need 2 more posts before i can post the link to the blackbox file
im on a fs-i6s transmitter
ive done the esc sync in betaflight
all motors seem to spin up more evenly in Betaflight
but still seems like motor 1 is more powerful
any thoughts?
Welcome to the forum! What ESC protocol have you set in Betaflight? Most use DShot now, in which case no calibration is required. Just go into BLHeli configurator and set endpoints to 1000-2000
d-shot600- ill try to set endpoints in bheli.
in these instructions from arris
ive tried dhsot 300 and 600 they seem same , possible it doesnt support 600?
it says to: "set it to ESC/Motor Protocal: DSHOT 300; MOTOR STOP: Enable;" in configure
also to: "Plug the battery, and choose the “JR/Spektrum/Graupner” in drop down menu," in receiver
this makes all the controls wrong though.
the manual:
http://blog.arrishobby.com/wp-content/uploads/2017/06/ARRIS-X220-PID-Tuning-Manual.pdf
Either setup tab @ the top or configuration tab. AETR1234 is what you want if you are in mode2= throttle on left stick. Did you perform the update to all esc's @ once. Maybe try multishot,
Last thing try a board reset on the setup tab. Don't load any backup. Start the process a fresh.
