X8W Transmitter Signal Stength Bars Flashing
Quest
Viktor
P
psicmar-6
Guest
CHECK MY REPORT ABOUT TRANSMITTERS SIGNAL OUTPUT FLASHING. IS A FULL EXPLANATION ABOUT THIS ISSUE. TO DESABLE THAT DOES NOT EXPLAIN WHATS GOING ON, THERE IS MUCH MORE TO IT. IS A VERY USEFULL FUNTION.
YOU CAN FIND IT IN DRONES STABILITY ISSUES, OR CHEC ME OUT psicmar-6
IS VERY IMPORTANT.
P
psicmar-6
Guest
maybe the beginning of my report sounded a little hard, i did not intented to point fingers at anyone. is just that i dont like gossip. from now on i will just stick about the real pourpose of this sharings. what is important about my report is the tec facts only, ignore the beginning.
Quest
Quest
P
psicmar-6
Guest
QUEST IM A NEW MEMBER AND I DONT KNOW HOW THIS BLOG WORKS ENTIRELY. SORRY. IM A RC MODEL AIRPLANE FLYIER SINCE SEVERAL YEARS.
ABOUT YOUR PROBLEM I WILL EXPLAIN. MOST TRANSMITTERS HAVE A FUNCTION THAT ALLOWS YOU TO LOWER THE SIGNAL OUTPUT. THIS IS SO YOU CAN PERFORM A RANGE SIGNAL TEST.
BEFORE YOU FLY YOUR NEW MODEL IS EXTREMILY IMPORTANT TO DO THE FOLLOWING FIRST YOU HAVE TO MAKE SHURE YOU HAVE BRAND NEW BATTERYS IN YOUR TRANSMITTER, AND THE DRONE BATTERY FULLY CHARGED AND DO IT WHERE YOU HAVE PLENTY OF SPACE, NO HIGH VOLTAGE WIRES AND NOTHING IN BETWEN YOU AND YOUR DRONE.
YOU KNOW THAT PRESSING THE RIGHT TRIM IN THE RIGHT STICK KEEPING IT PRESSED AND TURNING ON THE TRANSMITTER IN THE SAME TIME THE SIGNAL INDICATOR WILL START FLASHING. THIS MEANS THAT THE TRANSMITTER ENTER IN LOW SIGNAL OUTPUT.
NEXT YOU TURN ON THE DRONE LINK IT AND MOVE THE THRUDLE SO THE MOTORS START TURNING BUT JUST ENOUGH TO NOT TAKE OFF.
NOW YOU WILL START WALKING AWAY SLOWLY FROM YOUR DRONE CHEKING THAT EVERY FUNCTION IS WORKING PROPERLY. YOU CONTINUE WALKING FURTHER PLAYING WITH THE STICKS IN THE SAME FASHION UNTILL YOU REACH A REASONABLE DISTANCE LETS SAY 20, 30 METERS.
IF THE DRONE IS STILL WORKING YOU ARE OK. CONTINUE WALKING AND IF THE DRONE STOPS RESPONDING YOU STOP THERE. IT DOES NOT HAVE TO BE UNTILL THERE IS NOT RESPOSE BUT ABOUT THE DISTANCE I MENTION BEFORE IS O.K.
THE INTERESTING PART AND THE MAIN REASON IS THIS,.
IF YOUR DRONE DOES NOT RESPOND. WHEN YOU ARE IN A SHORT DISTANCE LETS SAY 5, 8,10 METERS OR LESS YOU ARE IN TROUBLE.
THIS MEANS THAT THE TRANSMITTER AND DRONE FAILED THE TEST. DO NOT FLY
WHAT TO DO? YOU MOST LIKELY HAVE A PROBLEM WITH SOME OF THE TWO ANTENAS THE TRANSMITTERS OR THE DRONES OR BOUTH.
YOU HAVE TO OPEN THE TRANSMITTER AND THE DRONE SO YOU CAN CHECK THEY ARE WELL ORIENTATED OR WELL CONECTED, NO WIRES VERY NEAR THE ANTENAS OR ON TOP OF THEM. ALL THIS DIMINISH THE OUTPUT OR RECEIVING THE SIGNAL CONSIDERABLY.
ONCE YOU CONVINCED THAT NOW IS WORKING. PERFORM THE TEST AGAIN.YOU DON HAVE TO REASSEMBLE THE DRONE COMPLETLY, YOU CAN LEAVE OUT THE PROPS THE STANDS, BUT CLOSE IT COMPLETLY. AND SO ON UNTILL WORKS PROPERLY. IF NO MATTER WHAT YOU FIX, THE TEST KEEPS FAILING THEN YOU HAVE FAULTY DRONE MOTHER BOARD OR THE SAME FAULTY TRANSMITTER. SOMETIMES THAT HAPPENS BUT NOT TO OFTEN.
I YOU FIXED THE PROBLEM. OR THERE WAS NONE FROM THE FIRST TEST. NOW YOU DESABLE THE FUNCTION, THE SIGNAL OUTPUT WILL BE BACK TO NORMAL AND THE SIGNAL WILL NOT BLINK ANYMORE. AND THE DRONE RANGE SHOULD BE ACCORDING THE SPECS OF THE DRONE.
NOW YOU CAN FLY MUCH MORE CONFORTABLY.
some transmitters may vary in the way you activate or deactivate this function depending on the brand model etc. very basic or small drones may dont have it.
I HOPE THIS WILL HELP YOU
ENJOY YOUR DRONE
