UAV Futures inspired $99 build
Discussion in 'Build Logs' started by roger jones, Mar 12, 2018.
Tags:
  1. roger jones
    roger jones Well-Known Member
    @mozquito1 when you say "Solder the esc power leads, test them." how do you test them?
    I also have a 4 in 1 esc if this changes anything?
    I have this TX on my list, but I am going to get it to fly first :) (recommendations welcome)
    https://www.banggood.com/Eachine-VT...1081&p=CG24181822629201506N&cur_warehouse=USA
    So rather than tin the two wires you strip of more of the outer, then twist them together and apply solder at that point?
    I have this flight controller
    https://www.ebay.co.uk/itm/F3-Fligh...hash=item25ebfd06e0:m:mkXVssO_zEEVJNG7vkN7fLQ
    which comes with Cleanflight.
    Is Cleanflight another variation of Betaflight?
  2. mozquito1
    What's the score with them motors roger? Heatshrink & solder them together or bullet connectors.
  3. mozquito1
    Each wire you solder can be checked with the multimeter to see if it has a proper conductive joint. & not a dry one.
    The ground is open right through the system. So if you go black to black & it doesn't make a sound, somthing is up.
    From my knowledge, maybe the gyro doc can comment. But red is the same, but can have switches where the circuit ends until powered on or switched on.
    But it's mainly the esc & pigtail.
    If you go red to black & it beeps then you're about to burn money & time.
    You have shorted somthing. If you cut wires @ your desk or whatever, always blow the quad off before a lipo plug in.
    Spork likes this.
  4. Spork
    Spork There is no spoon
    I've seen that VTX in a lot of builds and have heard it's good for the money. Others may have better information.
    Why wouldn't you tin? It makes soldering life SO much easier. If you are only twisting it together to make it easy to hold together, you may want to look at using a solder buddy or helping hands.
    Check out Joshua Bardwell's tool list for a few different styles and price points: https://www.fpvknowitall.com/ultimate-fpv-shopping-list-tools/
    BetaFlight was born out of CleanFlight. They are similar, but different. In some cases (maybe all - I don't know), you can put BetaFlight on a CleanFlight board.
    Here's a tutorial I found on how to do this (haven't done it obviously and there may be better tutorials - just the first one I found).
    Obviously, wait until someone smarter than me chimes in to confirm or correct me.
    https://www.aldeid.com/wiki/From-Cleanflight-to-Betaflight
    mozquito1 likes this.
  5. mozquito1
    I used to use cleanflight but I took the betaflight standalone off github to try.
    & cleanflight took a while & for all I know still has not released a standalone.
    You can swap the programming on it to BF pretty easy. I prefer BF now anyway.
    Does CF have osd? Anyone. The fcb you got in that 2nd link ain't to hot. It's an old MPU6050 which we did warn you about but it's cheap. I know the score. But a decent knock will kill the gyro.
    It's just an old naze32 that's been rechipped basically with the arm F3 but left the old gyro. Maybe alright for a bit of angle mode flying which I only recommend for a maiden or test.
    You need to start on acro ASAP even LOS.
    But definitely suspect for acro,
    Not recommended o_O
    That vtx is ok. I get about 150-200 in a field on my IRC Duo. I do only have a little whip on it. I have a clover on a u.fl for the 130 but it's OK for now.
  6. Spork
    All good stuff, Moz. Just wanted to thank you for that line, as I never would have thought of that until something bad happened. :oops:
  7. roger jones
    and finally off to a shaky start. Plumbing yesterday seemed easier. :)
    After all the prep, I started soldering at the wrong end of the drone!
    Hence the added notes so I can double check. I think I got lucky :) Worst case it could be soldering practice.
    Quite why it feels like rocket science! (Electrickery :confused: :))
  8. RENOV8R
    Uh oh, I don't see shrink tube on ANY of your solder connections.
  9. Badfish
    Badfish JA.O.A.T.
    Right. I found myself searching for a roll of tape as I scanned the pics.
    Those wires need to be individually wrapped as well.
    roger jones likes this.
  10. roger jones
    ? @RENOV8R
    Each joint has an individual heat shrink added and the yellow heat shrink over the top to tidy it up.
    Starting to realise why most builders use masking tape to hold the cables down.
    Spork likes this.
  11. mozquito1
    I got myself 2 set of spring loaded tweezers. Invaluable.
    A little fan also helps cool thing down a bit faster.
  12. roger jones
    Spork likes this.
  13. mozquito1
    Just a fan as those ground pads take some heating up coz the ground is open throughout the whole system. I just put it in front to cool down as doing a few grounds @ once can kill the board.
  14. mozquito1
    I had caps slide about before today.
