Did you get a multimeter for continuity tests.
Multimeter ? Did somebody say multimeter ? ... I've got about fourteen at last count ... lol ...
Swap the standoffs for the rubber vibration mounts.
Roger you can't go wrong with any of the esc's on RadioC.Com, especially the one I use. Pocket rocket. £5.90 Dshot.
If you can get any I just bought the last 9 again. But they will put them on back order.
Adding unneeded cabling does not 'remove another level of complexity,' just the opposite actually.Rather than rotating my flight controller to enable easy access to the Micro USB for configuration.
What about using one of these to remove another level of complexity from a first build:
Thoughts?
I did have 6 I just gave one away with my old i6 Tx. Then I had 5 & a spare board & I took my qav-r apart to put fresh wiring on & redo the joints but I fried motor port 1 somehow. So as it was a 180 or 3" frame I not really got spares. So I have orderd a new geprc chimp, just a cheap 215mm frame 5" & a new fcb. Omnibus F4 v3.! How many drones do you have @mozquito1 ?
https://www.ebay.co.uk/itm/Micro-US...661774&hash=item1edb4017b3:g:pQcAAOSwnH1WYV1A
Micro USB 2.0 Type B Male To Female M/F Extension
Thoughts?
Mount your FC with usb port facing where you want it. The setting is the simplest setting in the world. We'll show you where to do it when you get to that point, it's just the matter of changing an 0 to a 90Thanks @Spork
Technically it will work, it just felt like one less thing to have to set.
That said I guess I will need to configure other elements is either Betaflight or Clearflight.
