davidhk129
Ok.
Thanks to everyone replying to this thread.
The EX2H has arrived.Yes, and post a couple pics when it arrives. Hope it doesn't take too long
Thank you.Shouldn't affect the performance. If it was me, I'd just put a piece of duct tape over it. Not exactly professional but would be an improvement in aerodynamics for sure
It appears there's a plug for the camera.
The "void" in the front appears to only be for an LED light
Will this camera work on Eachine EX2H ?
If yes, how?
MJX C4000 Aerial Sport Actioncamera 1080P For MJX Bugs 3 RC Quadcopter
Took the EX2H out for its "maiden flight".
As it turns out, it has 2 modes...… Professional mode and Altitude Hold mode.
So, I am saved.
It flew beautifully. Steady like a rock. I can feel the power of the brushless motors. Relax. I am not a convert yet.
But now, I will have to find a really open field to try this big sucker out.
For $99 + $20 shipping. I have no complaint.
There is one disconcerting matter...…. the battery flimsy connecting plug.
When plugged in, it is hard to pull out. What do you call it? JST plug? The connection to the drone is so tight I am afraid I might rip the wire out from the little plastic "socket".
Next thing is to check out the cost of a 2nd battery.
P.S. RE : fpv camera.
C4000 cameras is what I need because my smartphone cannot support 5G version.
I fail to find one that can just plug into the micro usb port of the drone belly.
I sanded it down a bit. That did the trick.The battery uses an XT30 connector it will loosen up over time. If its really tight, you could lighty sand it down abit to remove some material.
Dont forget you could easily fit a 5.8ghz analog system the EX2H. And there are 5.8ghz receiver adapters available for smartphones.
