Marin
So, i got my 1st bigger quad a few days ago, a Eachine racer 250 to be exact, and somehow managed to burn one of the ESC's while setting it up in Libre pilot.
Burned ESC's
At 1st i did a firmware update, which reset the whole quad and led to a crash, so i decided to go through the vehicle setup wizard. As i was going through, step by step, at the ESC setup step, after i got 3 ESC beeps, one of the ESC's just started burning. More specifically it was the chip above the yellow wire that started burning(The ESC's used http://www.banggood.com/Eachine-Racer-250-Drone-Spare-Part-Simonk-12A-ESC-2-4S-p-1014103.html) .
Does anyone know why this happened? I picked the middle ESC as the type (superspeed or something like that?), and followed the steps as instructed. Was it my fault, or did i just get a bad ESC?
Libre pilot
Is there any good tutorials for libre pilot? i know there's a documentation, but having someone explain it can only help.
Batteries
In the above mentioned crash the balance charger connector got destroyed, which i find pretty strange because i made sure it was at a safe spot... But anyway, i need a new LiPo, and searching for one is so much more confusing then it is for RC cars. It seams like only 1500 mAh batteries fit the quad as it is, but it would still be good to know what brands to stay away from and which i should look for.
Burned ESC's
Libre pilot
Batteries
