No response from FC or ESC
Discussion in 'First Build' started by Jez, May 29, 2018.
Tags:
  1. mozquito1
    Google the model & look it up.
  2. mozquito1
    Did I mention mine was £12.99 lol
  3. mozquito1
    OK calm down, don't like wet yourself :D
  4. Jez
    Jez Member
    Mines the Seller WLC100
    Amazon says max is 900F... Definitely destroying my FC.
    I hear a lot of good things about the TS100 though!
  5. RENOV8R
    You can program it to play tetris hahaha
  6. RENOV8R
    Celsius
    Dugdog47 likes this.
  7. RENOV8R
    Yes, you want about 600-650 F
  8. Jez
    Jez Member
    How do you control it to play Tetris?
  9. Jez
    Jez Member
    So if my ESC is still getting battery voltage out the motor pads, does that mean it may still work? When I solder motors to it, they don't beep on power up.
  10. mozquito1
    No. The esc/fcb can tell if the power is evenly distributed, & if you bust a cap it will know & not let you fly.
  11. RENOV8R
    It has control buttons
  12. Jez
    Jez Member
    Just got my parts in today. Will solder at a lower temp this time lol
  13. Jez
    Jez Member
    Just figured out whats wrong. Getfpv has two images of the ESC, top and bottom. Both showing the same pin callout. So mines been wired completely wrong cause of wrong information...
  14. Gyro Doctor
    That's just about perfect. :D
    I run at 382 because it's an extra fine tip. ;)
    Remember folks, you want to "hit and git it", NOT linger with the iron on anything waiting for
    the heat to build up, THAT's how pads and traces get fried or adjacent parts get cooked; ruining PCBs. :oops:
  15. Rick M
    Ren, I've looked at that iron. My only concern has been that I dunno who the OEM is, and everyone sells them on Amazon with their own names. Should I have any concern about it not being OEM?
