pdmike
Extremely Popular Member
Little problem calibrating my IMU. Phantom 4. I got to the screen where you hit Calibrate. I put the quad down on a perfectly flat surface and hit "Calibrate." I was going fine until it got almost to the end, and then it just sat there. It never finished. I turned everything off and then on again and tried it again. When I hit calibrate, it went right back to the point where the green line was almost to the end and just sat there.
Is that all there is? Isn't it supposed to finish calibrating?
