Hi mate Go into monitor screen it will give you a value for each channel they all must read ZERO not aux this a switch channel the rudder will be reading some thing ,go into the transmitter servo set up( sub trims is what your looking for ) now adjust the sub trim so the monitor screen on the KK reads zero on the rudder input , I think your adjusting in the wrong screen after you do this and all inputs are zero make sure quad is level and re-calibrate sensors
Just looked at manual its on page 5 receiver test screen all must be zero
http://www.hobbyking.com/hobbyking/store/uploads/861944502X1166223X15.pdf
