Glo
So, some of you know I have this Flying 3D X8 that Gearbest sent to me with problems. It's looking like I am stuck with this so now I need to figure out what direction to go. I'd rather keep and build something with this if practical, but I will part it out if it makes more sense.
The first issue right now is figuring out what this board is that is the problem. Searching parts online has been no help as none of the parts available for this quad look like this at all. Also one site (http://www.rcgroups.com/forums/showthread.php?t=2217137) that has a ton of info on this quad has a totally different looking board.
If I can find something to replace this board with for a decent price I will, then get a frame and start my build. Otherwise I'll just sell the other parts that are good. (FC, ESC's, Motors, Receiver with telemetry, Transmitter, GPS module)
This is the bottom of the board I cannot identify
Here is the other side. The white box below is of course the FC. You can see 2 of the 4 plugs for side LED's on the corners. The larger wires coming in at the top are from the battery. The little yellow soldered wire close to the top goes to the main rear LED (the main LED has 3 more wires going to a plug into the FC.) The 8 wires soldered in close to my fingers go to the ESC's. There are 3 wires going to a plug for the USB port at the front. All remaining wires go to plugs going into the FC.
I wanted to believe that this is simply a power distribution board, but I cannot find anything out there with this many connections. I found one that has a single connection for LED, but not 4 (or 5). I also could not find any that I was sure had a spot for the USB. With the USB port giving access to the FC, why does it go through this board?
I have tried searching this number along with the words "power module"; "power board"; "flying 3d" and many other variations, but still cannot find anything.
Thanks in advance for any help. I hope someone can point me in the right direction for a solution so I don't have to part it out.
