wafflejock
Sounds like there should be a bind button on the transmitter somewhere you'll need to hold down while powering up the transmitter to get it to search. You usually need to hold the bind button or toggle switch until the receiver gives a solid light. Once it's bound can move on to betaflight configuration of the receiver. Without doing that config won't be able to arm or do anything but will allow you to customize what your switches do etc. as well. The solid light is all we're going for at the moment though. The initial slow flashing is probably when it's looking for already bound transmitter that is on.
