Global x183 is not taking off
Discussion in 'General Discussion' started by Gimhan Sumanasekera, Feb 2, 2018.
Tags:
  1. Lloyd Quick
    Lloyd Quick Member
    One long and 2 short flashes means your calibration attempt failed.
    Please recalibrate again. I suggest watching the video on u-tube.
  2. Thanks for the "info" I'll give it a go when the replacement transmitter arrives, Mine is a dual GPS and they have indicated that a replacement transmitter will be sent.
  3. Lloyd Quick
    Lloyd Quick Member
    Let me know when you get your new transmitter how it works.
    Lloyd
  4. Will do, thanks for your input.
  5. Mine is the Dual GPS X6 Follower and it's the wrong remote, Chinese supplier has offered 40% refund and I keep the drone, I don't know why they won't just exchange the remote! I finally calibrated it after countless attempts and it flies OK. My advice, only purchase from proven suppliers.
  6. I got it to fly but without the follow me and 360 functions, all I want is for them to replace the remote.
  7. Rick M
    I always use PayPal for purchases from overseas suppliers. That way I can dispute the charges with PayPal if I have an issue.
  8. Lloyd Quick
    Lloyd Quick Member
    I am pleased you got it to fly.
    Lloyd
  9. Have ordered new drone from Australian supplier with the same functions ( Much higher cost but less aggravation )
  10. Kainite
    Kainite New Member
    Hi, I do have the same problem my don't have dual gps and the buttons don't work so i don't have "follow me" with camera 4k (bad publicity), but after fly for a few minutes or less the rx battery stays at 6.9v and the lights do like code more ( -.. -.. -.. ) and never go (------) and don't fly it seems that this is blinking code is regarding the batteire being low? usually calibration dues ( .. .. .. ..) but there are no code information on the manual and support don't exist, could anyone have the lights code meaning?
  11. Jackson
    I'm assuming the 6.9V is triggering the low battery voltage warning. Use a meter and check the bat voltage right after you charge it, it should be around ~8.4V.
  12. Lloyd Quick
    Lloyd Quick Member
  13. Jackson
  14. Lloyd Quick
    Lloyd Quick Member
    That looks great!
    Lloyd
  15. Kainite
    Kainite New Member
    That is actually what i get after a full charged but since this is the original batteries as Lloyd mention i can only run for 3min or less. Thanks for the tip.
  16. dweber
    dweber New Member
    Hope I can jump in here. The charger for this follower gps 183 is driving me nuts. Sometimes it will blink green and red, then it will show two small lights green and red solid. I assume when it has stopped blinking and is solid green and red than the battery is charged. Even then it is a guess as to what the charge will be, but it has never gotten above 7.0 mostly stays in th 6.4 range and that may be after 3 hours of charging. Where can i get a real charger for this battery? Drone hasn't flown but one time reasonably well then returned home automatically and hasn't hardly flown decent since. Thanks for your help.
  17. 2Hover
    2Hover Member
    Hi, wondering if you solved the problem yet? It appears Lloyd Quick had same problem with same drone and solved it by re-calibration.
    Did you set your sticks to the "mode" you're used to? ex: In the US. its left= throttle.
  18. Lloyd Quick
    Lloyd Quick Member
    I went on u tube and watched many videos of calibration, and tried each one, many times before I was successfully.
    Please keep trying.
    Lloyd
