Can I use fatshark fpv goggles on a eachine e520s? If so how do I set it up. Thanks in advance.
S Sire New Member Apr 1, 2020 #1 Can I use fatshark fpv goggles on a eachine e520s? If so how do I set it up. Thanks in advance.
LoneRCRanger Well-Known Member Apr 1, 2020 #2 If it does work and you use them, it is advised that you do not fly in close proximity to cliffs. gorges and canyons!
S Sire New Member Apr 1, 2020 #3 LoneRCRanger said: If it does work and you use them, it is advised that you do not fly in close proximity to cliffs. gorges and canyons! Click to expand... Thanks for the advice
Dugdog47 Well-Known Member Apr 2, 2020 #4 The e520s uses wifi for video transmission so fatshark goggles won't work. You need a drone that uses 5.8ghz analog for video transmission.
