Darthdamo74
Hi folks !
After finally out growing (crashing in spectacular style) my second hand Parrot AR. I took the plunge and after watching lots of videos by painless 360 and Joshua Bardwell I ordered my parts for my first budget quad copter.
Frame Rooster (clone)
FC Omnibus F4 w BEC, PDB, OSD
TX FS i6s
RX FS-A8s (clone)
Lipo. 3s 1500 mah 35c x 2
Esc. Emax 12a Blhelli which came as a kit with some unbranded 2205 2300kv motors
I wanted to get it LOS flying for around £200 and as I was under budget had a couple of ciders and bought a Matek VTX HV, lollipop antenna run cam split 2s and a thing to turn my smartphone into FPV Google’s, but I haven’t got that far into the build yet.
All was going well, lap top, iPad, soldering iron, coffee, lots of coffee, and a box full of electronics.
TX hooked up to volecidrone, beta flight installed and communicating with the FC, FC updated. Time to get started. Frame put together easy, motors fitted, ESCs wired to the motors and FC battery lead and smoke stopper connected and the motors all spun in the right direction, great.
Except the motors would only run at low power very low power. Hmm try updating the ESCs and BLheli couldn’t see them also my rx had a solid light so I was thinking it was bound but not responding in beta flight. I tried all sorts eventually I had re soldered and changed things about so much that I’ve de laminated the pad for the signal wire on motor 1 I’ve tried sending it to a uart but nothing and the motors won’t even spin, I think the ESCs are bad so I’ve ordered some new parts spadix 20a ESCs the type you don’t have to worry which way the wires go and a matek F405 STD and FC Hub PDB. Hopefully this thread will get some interest so I can rebuild with a bit of coaching.
Cheers Damo
TX FS i6s
RX FS-A8s (clone)
Cheers Damo
