RENOV8R
Having just finished the Cerberus V2, I was lucky enough to nab one of 30 prototype version Cerberus V3. OK this isn't just a V2 with a couple tweaks, it's a totally new design. The most obvious feature is the channels in the arms for the motor wires. Like all Flyno frames, the craftsmanship is amazing with all rounded edges and countersunk holes, and is designed to accept only a 20X20 flight controller and micro fpv camera. It's not the lightest frame on the market at 96 grams, but still not bad considering it's a full 250mm frame. I did have an issue with the motor wires not fitting in the channels and not able to go through the space in the frame but it was an easy fix with cutting a couple grooves in the small top plate. Not ideal but this is a prototype and Flyno is aware of the issue. Anyway, here's a parts list:
HGLRC F440 20X20 micro stack with F4 FC and whopping 40amp BLHeli_32ESCs https://www.racedayquads.com/collec...-controller-osd-40a-blheli_32-3-5s-esc-no-vtx
EMAX Lite Spec 2206 2550kv motors
https://www.racedayquads.com/collec...ite-spec-ls2206-2550kv-racing-freestyle-motor
FRSky R-XSR Receiver
https://www.racedayquads.com/collections/frsky/products/frsky-r-xsr-s-bus-micro-receiver
Runcam Eagle Micro FPV Camera
https://www.getfpv.com/fpv/cameras/runcam-micro-eagle-800tvl-wdr-16-9-4-3-cmos-fpv-camera.html
IRC Tramp VTX
https://www.getfpv.com/fpv/video-transmitters/immersionrc-tramp-hv-5-8ghz-video-tx-us-version.html
Here's where I'm at so far, still waiting on the camera and vtx
IRC Tramp VTX
