MalcB
Hi Guys
After simply weeks of trawling the net, with brain getting absolutely full to bursting, with more acronyms than you see on Douglas Prom at T.T. week, I decided to have a go at building my own Quadcopter, with absolutely NO experience whatsoever.
Or if you prefer a more accurate description, I'm going to try and get this 'ere Plank and aluminum
sawn in half clothes rail, to FLY, with the help of some hopefully suitable motors.
What I really need is you Guy's thumbs up on my mathematics and conclusions.
The build I am trying initially has a plywood base of about 480mm (19") x 125mm (5").
Not unlike this:
(This is what I am going to do all my hacking and gluing on, hopefully to end up with a template
for something lighter).
Current weight of bare frame, arms and motor mounts 560g
A little heavy I know, but without any other components yet, not sure where to carve out !
As far as I can calculate, with FPV, Xaomi Yi and Gimbal final AUW should be probably 1465g.
Applying the 'Double the Weight, and add 20% for luck Rule', I've seen, brings us to 3516g
Divide by 4 and each motor has to give 879g of thrust.
I've seen RCXBE2217-9 930Kv which have quite taken my fancy, and are claimed to give 1000g of thrust (each) with a 10 x 4 prop @ 6926 RPM.
My limited knowledge suggests these would easily allow my build to hover @ 50% throttle.
My question is:
If I can manage to reduce my AUW by at least 260g (ie the weight of a 3000mAh Lipo) which I believe, giving a weight of 1.2Kg these motors aren't going to be TOO powerful are they ?
Cheers
MalcB
Not unlike this:
My question is:
Cheers
MalcB
