Vase - hollow inside
davidhk129
Unlike some stl files found in the net, this one is for "real."..….. hollow inside, not solid.
Downside:
Took over 10 hours to print, and it's only 3 inches tall. Nuts! My initial plan was to print a regular size first. If satisfactory, print a bigger size. Forget about that.
Many "holes" were plugged with plastic. Pain in the ass trying to pick clear the holes. Good thing I have a set of precision screws. one of them is tiny enough to pick the holes.
11 hours? Geez!
You might like to try vase mode it's the fastest way to print but just does one wall and continuously moves up instead of doing layers so only works with vases basically
can search for vase mode for your slicer if you want to try it out with some models doesn't work for a lot of things but fun to see something print fast
