Turnigy 9x unusual setting problems.
Quadman
After buying a new quad and loosing the settings on my Turnigy 9x I need to reset them correctly..
I have followed online instructions perfectly and made sure the connections are correct but.!!!
My throttle always moves the 'U' channel, in a perfectly synchronized way..
Mixing can be inhibited, pitch and throttle curve set the same but still the same issue..
Switching stick modes just causes the right elevator stick to do the same..but I have noticed that when I select 'mode 2' it will only display 'mode 1'
Settings are in Heli mode..
Standard Turnigy 9x receiver & TX, Naza M Lite, DJI 450 frame..
Please someone help..!!!
You tube is your friend. I have a DX8 and must have watched 20 hours of videos to get my quad working perfectly. It really sucks that owners manuals are so incomplete and you have to rely on you tube and web forums. A local club can be helpful too.
I have a DJI 450 and Naza M lite as well. I went through a similar problem not long ago when I lost the bind between my quad and DX8 for some unknown reason. I found a few problems but one thing I found was in the DJI software I did not have PPM, S bus or Traditional checked. Mine runs on Traditional. I assume your bound because the only way you would know those symptoms was if you were watching it with the DJI software open?
Thanks for the reply John..The answer wasn't found on any forum or on Youtube, or at least I didn't find it..
The answer was to only connect the 4 main auxillary channels to the NAZA while programming the 9x
I looked everywhere..The original seller told me to try this and I have seen no reference to this anywhere..
