TransTEC Frog Lite 218mm Carbon Fiber 4mm Arm X Frame DIY Frame Kit RC Drone FPV Racing Multi Rotor
Description:
Item name: Frog Lite
Wheel base: 218mm
Material: 3K carbon fiber
Upper shell: aviation aluminum-alloy
Screws: 12.9 class screw
Weight:
Frog Lite: 95g
Features:
Ultralight 3K full carbin fiber
Aircraft grade aluminum alloy
4mm thick chassis, true "X" frame
Frog Lite version: parted bottom plate & frame arms
Recommended Parts (not included):
Propellers (5040-5045):
10 Pairs Racerstar 5042 3 BladePropeller 5.0mm Mounting Hole
10 Pairs Racerstar 5051 3 Blade Propeller 5.0mm Mounting Hole
10 Pairs Racerstar 5048 3 Blade Propeller 5.0mm Mounting Hole
10 Pairs Racerstar 5040 3 Blade Propeller 5.0mm Mounting Hole
10 Pairs Kingkong 5040 5 4 Blade Propeller
7 Pairs KingKong 5045 3 blade Rainbow Colorful Propeller
Brushless Motors (2205 2300KV-2600KV):
Racerstar BR2205 motors
Cobra champion CP2205 motors
Emax RS2205 2300KV motor
DYS SE2205 PRO 2300KV / 2550KV motor
ESCs(20A-30A):
Racerstar RS20A V2 Blheli_S 2-4S ESC 16.5 Dshot600
Racerstar RS20Ax4 V2 20A BB2 48MHz Blheli_S 4 in 1 ESC 16.5 Dshot600
Racerstar RS30A V2 Blheli_S 2-4S ESC 16.5 Dshot600
Racerstar RS30Ax4 V2 BLheli_S BB2 4 in 1 ESC 16.5 Dshot600
DYS XSD 20A 3-4S ESC BLHeli_S Dshot600 Dshot300
DYS XSD 30A 3-5S ESC V2 BLHeli_S Dshot600 Dshot300
Flight controller:
Diatone D-Link F3 MPU6050 Integrated PDB 36x36mm
Battery(4S 14.8V 1300-1800mah):
Infinity 4S 14.8V 1300mAh 70C Graphene LiPo Battery XT60
Infinity 4S 14.8V 1500mAh 70C Graphene LiPo Battery XT60
Package included:
1 x Frog 218mm Frame Kit
YOU CAN GRAB IT AT BANGGOOD/GEARBEST/AMAZON
