Transmitter problem
thelakes
Active Member
hi so I've finally got my quadcopter working with setup wizard on openpilot now my next issue the transmitter won't work.
It binds ok but nothing happens. When i use transmitter wizard on open pilot i set it to mode 2 and when it says move the throttle stick nothing works but if u move the right stick left or right i then moves to the next pge but no stick movement moves me on.
I have the flysky fs-t6 i assume its probable some setting on the transmitter but i have reset that and still nothing any help would be great
Sorry but I'm on a naze, maybe different but blue is power, green flashing is safe and green solid is armed. It's a pain coming across these problems but you will suss it out, then next time it's a breeze. Good luck dude.
I'd say it's probably a problem with your software setup, not your transmitter. Are you sure you have PWM selected as receiver type? And is your receiver connected to your FCB correctly?
I'd say it's probably a problem with your software setup, not your transmitter. Are you sure your receiver is connected to your flight controller correctly??
yes everything is connected correctly... i think when i run set up wizard in openpilot i calibrated my esc i can set them all they run at 1116, when the battery connects they make the right beeps all the tutorials ive watched seem like its all done correctly. are there any good youtube videos or tutorials you would recommend that i could watch/read to double check what ive done?
haha a pain is the polite way of putting it. this is my first build ive enjoyed it and through trial and error sorted other issues so i hope i will get it sorted. If... when i fix it ill post what i did so it will hopefully help others in the future
Check out the video tutorials by Seafury Mike. He has a way of explaining things that even people new to the hobby can understand. Might also want try switching to Librepilot, Openpilot is obsolete and unsupported
I downloaded librapilot ran through setup wizard and transmitter wizard an it worked flew with my 1 battery worked fine went to the 2nd battery had a 30secondish flight landed didn't take off for a while so it disarmed itself I re armed it but nothing again it arms but nothing works again. So re did setup and transmitter wizard in Libra and it still won't work again so I'm thinking it could be the CC3D or transmitter. Do you think if I changed to a naze32 it could resolve the problem?
Go into your transmitter endpoint settings and make sure your throttle endpoints are 100%. If they are, bump them up to 125% and see if that fixes it.
