Dougienoob
This is my first build and am using a Mamba stack F405 MK2-F40, iFlight XING-E Pro 2306 1700KV motors, iRangeX Fli14+ mini Flysky receiver, EWRF 5.8Ghz VTX, with a Radiomaster Zorro radio (yes it is a budget build). Everything is soldered up with no shorting and I have successfully bound the radio to the receiver and have started configuring with Betaflight 4.3 watching Joshua Bardwell's Betaflight 4.3 complete walkthrough. I am only about 1/3 the way through the complete walkthrough series but everything seems to be working ok so far including successfully flashing latest firmware, arming and motors spinning in correct direction. However when testing without props on the bench using the radio and battery plugged in, once armed when I increase the throttle up beyond ~50% it seems to stay at that rpm and wont respond to throttle commands anymore. Disarming stops the motors of course.
Perhaps there is still something that needs to be configured with betaflight and I plan to finish JB's walkthrough series, but does anyone have any ideas as to why this is happening? Thanks
