agridronedesigner
A 60-second flow test of the EFT Flexible Impeller Pump under a 60V power supply —just real operating performance from start to finish.
Test Results
✔ Voltage: 60V
✔ Test Duration: 1 minute
✔ Pump Opening: 100%
✔ Total Discharge Volume: 21.7L
Throughout the test, the pump maintained a smooth and consistent flow with no noticeable interruptions, demonstrating reliable liquid transfer for agricultural drone spraying.
Built with a flexible impeller design, the pump is engineered to:
• Deliver stable high-flow performance
• Reduce the risk of clogging during operation
• Resist wear and corrosion when handling agricultural chemicals
• Support accurate and efficient spraying in demanding field conditions
If you're developing agricultural drones or upgrading your spraying system, we'd be interested to hear what flow rate and pump performance you look for in real-world applications.
Follow for more:https://www.effort-tech.com/
#EFTDrone #eftdrone #agdrone #AgriculturalTechnology #flexibleimpellerpump #dronepump #PumpTest #flowtest #waterpump #test #droneparts #Producttest
