Tarot 680 gimbal question...dji guys help
Pmac2002
First off thanks in advance.
I have a tarot 680. It is powered by naza m v2.
I was wondering if any of the dji phantom 3 or 4 gimbal and cameras would be compatible? Has anyone else tried?
Also can the flight control be taken from a phantom 3 and added to make the system think its a phantom?
Finally suggestions for camera and gimbal if the above is a no go?
I think you would have to use the dji remote, and the internals for it to work so it would probably be cheaper to just get a camera and gimbal.
What is the budget?
The gimbal control is just a channel on the DJI transmitter so any 6 channel plus transmitter will work the tilt control of the gimbal plugs into the gimbal tilt axis of the naza then you activate it in the assist on your pc , then on the transmitter assign a control channel most use a rotational switch
The DJI transmitter has a small lever on the back of the transmitter to control the tilt
