STEM big drone project-Help needed fast!!!
W
Wreathy Writer
Guest
Hi guys,
I am proposing to build a life saving drone for our STEM class. I have no previous experience with drones. My teacher does have but he is not agreeing to the idea particularly because of the feasibility of the project and the money. He usually does not approve of ideas which go over 1000 dollars. I have to make a very strong case. I need help in two areas:
Number one, I want to know what to buy for my copter. I want to build a copter that can lift upto 7 kegs weight and its own weight too. That can deploy falling medic kit bags from the air (I think I will have to use another very small motor to be able to make the kit fall down.) that can go fast! At least faster than an ambulance. That does not have a lot of post-flight work. I am planning to make my own frame. ( although if you have a great frame in mind that can handle such loads, please tell me) I want to know what material we should use ( we have aluminum, wood, fiber glass. We will be able to get carbon fibre if it is within budget) for the frame? What motor should I use? What propellers? Should it be quad, hex, or octa? If quad then plus or x- type? What ESCs? Should I use arduino board( we already have arduino boards in lab, I don't think they are ardupilots but I think we can buy ardupilots if it is within budget.) or should we use some other controlling board? What battery will be needed to conduct a reasonably long flight ( ideally 20-30 minutes)? What camera should I put on( I don't need very high quality, just something it can transmits? Possibly the cube camera??) what transmitter will it have? What receiver should there be? Can we make a smartphone based transmitter that can transmit data over data connection and act as an LCD for people to see how to perform procedures. It can also act as the camera maybe??
I also need some arguments to make my teacher let me do it. If you have anything in your mind that you can tell me to convince him, it would be great.
I really need your help guys. Please don't tell me it's impossible. I need to keep my spirits high!! Tell me it's possible right?
Thanks, I'm waiting for a fast response.
Oh the kegs was a typo, it's kgs. I just realized while righting this that my iPad is autocorrecting to kegs.
I have searched for some first aid kits and I have seen that my estimate of weight was wrong. I can bring it down to 4 kgs or even less since it's just a project and does not need to be carrying military grade first aid kits.
Is there any way we can do this now that the weight is less? If not than how much weight would be ideal for a copter under 1000 dollars. I can bring down the weight of the kit even more but I want it to be a practical kit too.
Don't tell me it's impossible please.
Is it better to use low Kv Motors? In addition, arethe specs in the eCalc are without any load? If yes, then should I use bigger motors, ESCs and batteries so it would be able to fly for 20 mins at 35kmph with the load?
