muazzamzam
hello uolls ,my sjrc f11 4k pro wifi not showing up in my iphone any idea what is problem? the camera also cannot control by controller , any one had a tools for flashing firmware for the drone and had a original firmware??
You probably knew all that already. At the risk of being redundant......hello uolls ,my sjrc f11 4k pro wifi not showing up in my iphone any idea what is problem? the camera also cannot control by controller , any one had a tools for flashing firmware for the drone and had a original firmware??
My mobile is 802.11 ac compatible but m'y SJRC F114K PRO'WIFI STOPS AS SOON AS I START THE DRONE'S ROTORS EVEN IF THIS DRONE IS NEW, JUST RECEIVED FROM BANGGOOD BUT NOT OPERATIONAL.You probably knew all that already. At the risk of being redundant......
SJRC F11 is a 5g wifi drone which requires a phone that has 802.11ac wifi in order to connect the drone with the phone.
Is your iphone 5g wifi capable?
From what I understand, which is not very much, not all iphones have 802.11 ac, i.e. iphone 5 does not.
I just recently bought an unlocked iphone 6s, first iphone I ever own. It has 802.11 ac.
This may sound crazy to you.My mobile is 802.11 ac compatible but m'y SJRC F114K PRO'WIFI STOPS AS SOON AS I START THE DRONE'S ROTORS EVEN IF THIS DRONE IS NEW, JUST RECEIVED FROM BANGGOOD BUT NOT OPERATIONAL.
I have tried with 3 other ones which are all compatible but the problem remains the sameThis may sound crazy to you.
Any chance you can try a different smartphone ?
After successful upgrade my firmware it's showing white and red light and not BindingI had a problem with the gimbal not working, others have reported wifi problems, that were fixed with a firmware update. A video is here:
The link he provides to the firmware: https://drive.google.com/file/d/1HeuNyMzfjeBz8Jzr3ILPMhpWPOOxejRK/view
I found out about this through the SJRC FB group: https://www.facebook.com/groups/sjrcdrones
I just unzipped the files into the top directory of the sd card, inserted it into the f11 pro 4k, turned the drone on, let it sit there until it automatically turned off. Removed the sd card, restarted the drone, connected my phone to the drone's wifi, checked the app and the firmware was updated. Tested the drone and the gimbal works now.
However, well, the firmware isn't on any official sjrc site... I asked the guy that made the video and he said they sent it to him... worked for me, but use at your own risk!
